Hi
I want to put some selects on my page to allow people to navigate through 3 levels of navigation i.e.
Department > Manufacturer > Product
but I only want to show one select at a time, so if someone selects from the departments it will reload page.php?department_id=1 with the manufacturers in that department and then they can select a manufacturer from the newly appeared select so it reloads again with page.php?manufacturer_id=8&department_id=1 and so on and so forth.
This I think will be fine, but I was wondering if I can get Ajax to do it without the page reload? I've got a couple of Ajax books which I had a flick through and couldn’t find anything matching it.
I’ve got some Javascript that will allow people to select the department, which then creates a new list in the select below it, but that means showing the select there with a "Please select from above" message which I would like to get around.
Any input appreciated
Cheers
Cheers
