Program Recommendation
24 Mar 2006
Can anyone recommend me a program which will show me my chipset temperature. I have an Asus P5N-E SLi. I’ve tried motherboard monitor but my motherboard isn’t supported.
Thanks
I'd go with Temp3 as being the most likely of those, however since your +3.3v seems a little low at 0v so I'd maybe consider just downloading Asus PC Probe since it will label everything better and will probably work better with the motherboard. :)
Installed Asus Probe. It doesnt give a reading titled northbridge. But there is one titled MB. What is this the temperature of? Is this the northbridge?
It's not the NB, I'd say the sensor is in or near the southbridge as it dropped quite a few degrees when I positioned a fan there.
No idea if there's even a NB temp sensor on this board.
