Looking for a program to control fan speeds. Tried speedfan but my venom's in push/pull on the H60 rad only go up to 1400rpm when I select 100%. They should go to 1900.
Speedfan is the best generic controller out there.
Other than that you need to see if you motherboard maker has an application.
If speedfan is allowing you to adjust the fan speed then I would expect you to be able to fine tune the settings in the advanced setup. I would not give up on speedfan just yet
If your using an asus mobo, theyre own ai suites fan xpert is pretty good. The rest of the ai suite features are pretty useless tbh. But ive always found fan xpert to be great for fine tuning fan speeds.
