Cybertronic said:
I did until a new version of Prime95 came outChris Beard said:You never did???
Captain Fizz said:XD
Prime95 has been around a lot longer.
(Orthos uses the prime engine)
Anyway - For Prime, copy & paste the extracted folder 3 times.
So you have 4 different Exe's to prime 95.
Then run each one and set it's affinity.
Then you have one running per core and they save their settings so you can have folder names of "Prime 0", "Prime 1" etc![]()
KX36 said:orthos beta stresses 2 cores. i assume u can run 2 instances of that. For Prime95, you don't need to copy the whole folder, you launch a second instance with the -A1 parameter.. and a 3rd and 4th, but i don't know how that parameter changes for more than 1 "assisting" instance, read the prime95 docs.
(make a shortcut and stick that on so u dont have to do command line every time.. or do a batch, but i cant remember how to run several things from 1 batch file without it waiting for one to close before starting the next.. too much time on linux has made me a DOS noob)
Then when u have enoguh instances open, set the affinity in each copy to each core. each instance will keep its own settings if its launched with the right command line parameters.
cybertronic said:
