Program to tunnel traffic
7 Apr 2004
Hi,
Are there any programs that can force a program to use a specific network adapter?
I'm trying to get a program to use a VPN connection but the program itself doesn't have any adapter selection options and it defaults to my other adapter which is no good :(, so i need something to encapsulate the program and force it to use a specific network interface.
Thanks,
Jack
These types of programs will typically follow the default route (gateway) in your routing table to try and find what they are looking for.
Can you reconfigure your default gateway to send such traffic where you need it to go?
