programm to measure RAM temperature?
not relli mate
i have looked quite a lot and i havent found one yet but tbh it doesnt relli matter if its stable and the CPU and MOBO temps are fine then ur RAM wnt be on fire:D
RAM doesnt have a thermometer built into it like a CPU and motherboard do. There are a lot of fan controllers that have temperature sensors on them, might be worth looking into and placing a sensor by your RAM.
For accuracy you really need an infra red thermometer.
Might be a bit out of scope for what you need tho.
You could get a front panel and place on of the probes on your ram, would work.
