programming noob needs help. couple of major bugs in simple program (C++)
15 Feb 2011
Slough
*edit*
problem is all fixed now. feel free to delete this mods
first, i really want to make it clear how much of a noob to programming i am. i only started programming in C in October, and moved on to C++ in February. right now the limit of complexity for me is classes and objects.
what i need the program to do is play a simple text based version of the classic game mastermind. when i had the program as one giant main function with no classes or functions, everything was fine. however, now i have put most of the functionality into classes i have the following two problems:
- the variable that stores the number of pegs in of the correct colour, but in the wrong place is stuck at zero, no matter how many pegs of the right colour are in the wrong place.
*edit*
fixed the overwriting problem. i made the 2D array's that store the guesses and the results too small
(insert blushing smiley here)
if anyone can explain in morons terms how to fix these problems that would be fantastic. ive attached the code at the bottom. please dont laugh, i know its pretty rubbish, but its all i know so far:
(using visual C++ 2010 express)
header file: mastermind class.h
Code:
#include <iostream>
using namespace std;
class mastermind
public:
	//all functions
	void set_random_answer_code();
	void set_custom_answer_code();
	void reset_variables(int guess_number);
	void print_previous_results(int guess_number);
	void enter_current_guess(int guess_number);
	void calculate_current_result(int guess_number);
	int game_won_check(int guess_number);
	void print_answer();
private:
	//all variables
	//counters
	int c1;
	int c2;
	int c3;
	//sentinals for checking right colour, right place, and right colour, wrong place
	int sentinal_g1;
	int sentinal_g2;
	int sentinal_g3;
	int sentinal_g4;
	int sentinal_a1;
	int sentinal_a2;
	int sentinal_a3;
	int sentinal_a4;
	int result_array_all[15][2];
	char guess_array_all[15][4];
	//guess arrays
	char answer_array[4];
	//temporary variables
	int temp1;
protected:
class functions file: mastermind class.cpp
Code:
#include <iostream>
#include <ctime>
#include "mastermind class.h"
void mastermind::set_random_answer_code()
	for (c1 = 0; c1 < 4; c1++)
		//seed random number
		int t;
		t = time (NULL);
		srand (t);
		temp1 = (rand() %6); //remainder when divided by 6
		switch (temp1)
			case 0: answer_array[c1] = 'R'; break;
			case 1: answer_array[c1] = 'G'; break;
			case 2: answer_array[c1] = 'B'; break;
			case 3: answer_array[c1] = 'Y'; break;
			case 4: answer_array[c1] = 'O'; break;
			case 5: answer_array[c1] = 'P'; break;
			default: answer_array[c1] = 'R'; break;
void mastermind::set_custom_answer_code()
	cout << "\nenter the colours of the four pegs your opponent will be guessing\n R = Red\n G = Green\n B = Blue\n Y = Yellow\n O = Orange\n P = Purple\n" <<endl;
	//need error checking!!!
	cin >> answer_array[0] >> answer_array[1] >> answer_array[2] >> answer_array[3];
void mastermind::reset_variables(int guess_number)
	//sentinals used in checking your current guess
	int sentinal_g1 = 0;
	int sentinal_g2 = 0;
	int sentinal_g3 = 0;
	int sentinal_g4 = 0;
	int sentinal_a1 = 0;
	int sentinal_a2 = 0;
	int sentinal_a3 = 0;
	int sentinal_a4 = 0;
	result_array_all[guess_number][0] = 0;
	result_array_all[guess_number][1] = 0;
void mastermind::print_previous_results(int guess_number)
	for(c3 = 0; c3 < guess_number; c3++)
		cout << (c3 + 1) << ":  " << guess_array_all[c3][0] << ", " << guess_array_all[c3][1] << ", ";
		cout << guess_array_all[c3][2] << ", " << guess_array_all[c3][3] << ", ";
		cout << result_array_all[c3][0] << ", " << result_array_all[c3][1] << endl;
void mastermind::enter_current_guess(int guess_number)
	cout << "enter guess" << endl;
	cin >> guess_array_all[guess_number][0] >> guess_array_all[guess_number][1] >> guess_array_all[guess_number][2] >> guess_array_all[guess_number][3];
void mastermind::calculate_current_result(int guess_number)
	reset_variables(guess_number);
	//calculate correct colour and correct place
	//result_array_all[x][0] == correct colour and correct place variable
	if(guess_array_all[guess_number][0] == answer_array[0])
			result_array_all[guess_number][0] += 1;
			sentinal_g1 ++;
			sentinal_a1 ++;
		if(guess_array_all[guess_number][1] == answer_array[1])
			sentinal_g2 ++;
			sentinal_a2 ++;
		if(guess_array_all[guess_number][2] == answer_array[2])
			sentinal_g3 ++;
			sentinal_a3 ++;
		if(guess_array_all[guess_number][3] == answer_array[3])
			sentinal_g4 ++;
			sentinal_a4 ++;
		//calculate correct colour wrong place
		//result_array_all[x][1] == correct colour but wrong place variable
		//character 1
		if(guess_array_all[guess_number][0] == answer_array[1] && sentinal_g1 == 0 && sentinal_a2 == 0)
			result_array_all[guess_number][1] += 1;
			sentinal_g1 ++;
			sentinal_a2 ++;
		if(guess_array_all[guess_number][0] == answer_array[2] && sentinal_g1 == 0 && sentinal_a3 == 0)
			sentinal_g1 ++;
			sentinal_a3 ++;
		if(guess_array_all[guess_number][0] == answer_array[3] && sentinal_g1 == 0 && sentinal_a4 == 0)
			sentinal_g1 ++;
			sentinal_a4 ++;
		//character 2
		if(guess_array_all[guess_number][1] == answer_array[0] && sentinal_g2 == 0 && sentinal_a1 == 0)
			sentinal_g2 ++;
			sentinal_a1 ++;
		if(guess_array_all[guess_number][1] == answer_array[2] && sentinal_g2 == 0 && sentinal_a3 == 0)
			sentinal_g2 ++;
			sentinal_a3 ++;
		if(guess_array_all[guess_number][1] == answer_array[3] && sentinal_g2 == 0 && sentinal_a4 == 0)
			sentinal_g2 ++;
			sentinal_a4 ++;
		//character 3
		if(guess_array_all[guess_number][2] == answer_array[0] && sentinal_g3 == 0 && sentinal_a1 == 0)
			sentinal_g3 ++;
			sentinal_a1 ++;
		if(guess_array_all[guess_number][2] == answer_array[1] && sentinal_g3 == 0 && sentinal_a2 == 0)
			sentinal_g3 ++;
			sentinal_a2 ++;
		if(guess_array_all[guess_number][2] == answer_array[3] && sentinal_g3 == 0 && sentinal_a4 == 0)
			sentinal_g3 ++;
			sentinal_a4 ++;
		//character 4
		if(guess_array_all[guess_number][3] == answer_array[0] && sentinal_g4 == 0 && sentinal_a1 == 0)
			sentinal_g4 ++;
			sentinal_a1 ++;
		if(guess_array_all[guess_number][3] == answer_array[1] && sentinal_g4 == 0 && sentinal_a2 == 0)
			sentinal_g4 ++;
			sentinal_a2 ++;
		if(guess_array_all[guess_number][3] == answer_array[2] && sentinal_g4 == 0 && sentinal_a3 == 0)
			sentinal_g4 ++;
			sentinal_a3 ++;
int mastermind::game_won_check(int guess_number)
	if (result_array_all[guess_number][0] == 4)
		return 1;
	}else
			return 0;
void mastermind::print_answer()
	for (c2 = 0; c2 < 4; c2++)
			cout << answer_array[c2] << ", ";
main file: mastermind.cpp
Code:
#include <iostream>
#include <ctime>
#include <stdlib.h>
int main ()
	int game_won_sentinal = 0;
	int guess_number;
	int noofplayers;
	int lives;
	mastermind game;
	cout << "MASTERMIND" << endl;
	//choose number of players
	cout << "for single player, enter 1 \nfor two player, enter 2" << endl;
	cin >> noofplayers;
	cout << endl;
	//colours: R = Red; G = Green; B = Blue; Y = Yellow; O = Orange; P = Purple
	if (noofplayers == 1)
		game.set_random_answer_code();
	} else
		if (noofplayers == 2)
			game.set_custom_answer_code();
	guess_number = -1;
	lives = 15;
	for (lives = 15; lives >= 0; lives --)
		//clear screen
		system("cls");
		//print introduction and instructions
		guess_number ++;
		//reset variables
		game.reset_variables(guess_number);
		//game description
		cout << "MASTERMIND\n" << endl;
		cout << "A combination of four colours has been chosen from the colours below." << endl;
		cout << "You must guess the combination your opponent has chosen within 15 tries" << endl;
		cout << "The number under 'pl' is the number of pegs that are the\ncorrect colour and in the correct place" << endl;
		cout << "The number under 'cl' is the number of pegs that are the\ncorrect colour but are in the wrong place" << endl;
		cout << "\nThe colours available are:\n R = Red\n G = Green\n B = Blue\n Y = Yellow\n O = Orange\n P = Purple\n" <<endl;
		//print format of how results are displayed
		cout << "g#  c1 c2 c3 c4 pl cl" << endl;
		//print all previous results (with all array)
		game.print_previous_results(guess_number);
		//enter current guess
		game.enter_current_guess(guess_number);
		game.calculate_current_result(guess_number);
		//game won check
		game_won_sentinal = game.game_won_check(guess_number);
		if (game_won_sentinal == 1)
			lives = 0;
	}// end of loop for playing the game
	//game won
		cout << "congratulations, you won" << endl;
		cout << "the correct answer was: " << endl;
		game.print_answer();
	//game lost
	if (game_won_sentinal != 1)
		cout << "sorry, you lost" << endl;
		cout << "the correct answer was: ";
	return 0;
*edit*
fixed the overwriting the previous guesses bug. idiot me didnt make the 2D arrays that store the guesses and results big enough
any help on my 'right colour, wrong place' not showing up would be great
*edit*
finally fixed this
apparently some variables that i had very clearly initialised were not being initialised
mods, feel free to remove this now
