Hey guys, bit of a lurker but I will be building a system after this week so thought I would seek some advice. This system will initially be a family PC with gaming, however within a year I will be buying a flat and this PC will then become my main gaming PC. Essentially this is why it will be a progressive build, I have money now, but by the time I am buying a flat any significant money will be going into that to keep the mortgage down although I will probably be able to spare a bit of money here and there for improvements.
I have a case which was given to me for free, its a Casecom 6788, which is a bit of a budget case but its not too big and looks ok so I am intending to use this for the build currently (unless that proves impossible) but when I move out I will probably be building a budget replacement (as I will be taking this PC) and use this case for that and buy myself a new one then.
So after all that waffle I have put together the build below, as I say It won't be having heavy games use at the moment, but later on I plan to install a CPU cooler, double the RAM, get a second 6870 and a solid state drive (will probably do this bit by bit) and then do some overclocking.
Thoughts on this build? Initially will want to limit to around 800
