Well its about time I start my new Build / Project Log. I have been planning my new build designing in a couple of different cases, IN-WIN 901, NZXT H440 and the one I chose to go with the Corsair 380t.
So lets go on with it.
As you can or cant tell from the name, the Trix ending I am using is because I am basing it on the Asus Strix Edition Graphic Cards, lot of people do ROG builds so I wanted to do something different so my colour scheme is orange and white, black, grey. without giving away to much information on how it will look. I have ordered some acrylic and my Dremel will be coming out for some fun too.
While that's all I am giving away on the colour and look, I can tell you there will be 2 x 240mm Rads and a 120mm Rad with 5 NB Eloops and all components under water inside this case!
Main Companies being used.
Asus
Corsair
Silverstone
Black Ice Rads
Bitspower
EK
NB Eloops
PC Components:
Case: Corsair 380t
CPU: Intel Core i7-4790K
MB: Asus Z97 VII Impact
GFX: Asus 980 Strix Edition
RAM: 8GB Avexir Core Extreme 2933MHz
Storage: Crucial MX100 512GB x2 Raid 0
External Storage: WD 2TB Passport - Backup / Media
PSU: Silverstone Stride 750watt "Gold edition"
Water cooling Components:
Fans: Noiseblocker NB-eLoop Fan B12-3 x5
Rads: Hardware Labs Black Ice Nemesis Radiator GTS 120
.........Hardware Labs Black Ice Nemesis Radiator GTS 240 x 2
Res: Alphacool Cape Fuzion Core 10 Acetal Black
Pump: EK DDC 3.25 X-TOP CSQ Laing DDC Pump and Pump Top : Acetal
Tubing: E22 10/12 Hardline Acrylic Tubing
Fitting: Various Bitpowers
Waterblocks: Various EK Blocks
so here is the 380t in its untouched flesh:
[reserved for 20th Sept when my delivery should be turning up (cant get it sooner due to new job and working) pictures will definitely be up as soon as it arrives from the guys at OcUK]
) I think it is quite a unique case which is why I like it so much. so you will have to see how much you can actually fit into this big but Itx case
