Project: 4-Quad (56k = no)
:o Niiiicee spec:o, will keep a eye on this, and also it says under your name 2 post's
what that mean :S
BillytheImpaler said:
Might it be a good idea to put some grommets on the edge of that mare metal, lest innate vibration wear through the tubing and cause a rupture?
Just what I was thinking. Very nice setup, lot's of shiny things :D
Part one is now finished, part 2 will be done in a few weeks time, have exams though that i need to revise for.
Part 2:
Re drilling of pipe holes + rubber
2nd D5+120.2 added to the system
not 100% sure on: radbox to store the radiators and pumps in
As for now here are some almost finished part 1 pics,
A quick bench......
nice speeds being shown but that random access time isnt great
keep the pictures coming
what temp is that quad at at 100% load with that water combo
Where are the second radiator and pumps going to end up?
I assume they'll be for the graphics card?
Idle @ 3.2ghz 1.4v is 39/39/40/40
Load @ 3.2ghz 1.4v is 55/56/58/58
More pictures later today when I get a memory stick for my camera, been using the on-board memory as I'm a cheapo :p
2nd rad will go on the roof of the case and 2nd D5 will go either next to the res or next to the rad.
Or
It could all be put inside a radbox, I haven't decided which way to go yet. :)
Looks sweeeeeeeet!!! :cool:
Love the X-Fi pro. Stupidly thought it was a Fatal1ty until i saw the light was blue. :p
Excellent build and nice pics fella!
Gonna give you 5 stars for the trouble. ;)
gt
