- 22 Sep 2011
- at home
Hello boys and girls!
Some time has past since I decided not only build, but also display computer for all doubters, non believers (in power and beauty of water cooling) and people who are generally interested in hardware.
As a log must have a title I named mine after a dragon in Philippine mythology that is often represented as a gigantic sea serpent. It is believed to be the cause of eclipses.
It appears as a giant sea serpent with a mouth the size of a lake, a red tongue, whiskers, gills, small wires at its sides, and two sets of wings, one is large and ash-gray while the other is small and is found further down its body [source: Wiki].
Cooling equipment:
CPU blocks: EK-Supreme HF - Full Nickel
GPU block: EK-FC6990 Nickel with backplate
VRM block: EK-MOSFET ASUS P8P67 - EN (Nickel)
RAM block: EK-RAM Dominator - EN (Nickel)
Reservoir: EK-BAY SPIN Reservoir - Plexi
Pump: EK-DCP 4.0 (12V DC Pump)
Radiator: EK-CoolStream RAD XTX (360) & EK-CoolStream RAD XTC (140)
Fans: Xigmatek XLF-F1256 Blue - 120mm
Fittings: EK-PSC Fitting 10mm - G1/4 E-Nickel & EK-PSC Adapter 45° G1/4 Nickel
Cooling equipment:
, but that little DCP pump is strong enough to push the flow. Tubes feel more sturdy and inflated once you power it up, hence a good pressure.
