Hi all and welcome to my build log
This rig i have assembeled for a freind and i have put this together out off the most powerful parts i could find regardless of make second hand or new for the budget so her goes
The budget: around £500
so i felt on this budget i felt i would have to second hand to get any really power and these are the second hand parts i have found all prices are with postage and for MM
PII X2 550 BE proven unlocker £68
2x2gb G-Skill Ripjaws 2000mhz/9-9-9-24 £70
His HD4870X2 2056mb stock cooling £108
Corsair TX650w PSU £45
Akaska Freedom cpu cooler £22
for the rest i though it would be best buying 1st hand as i wanted 6/gbs sata for the rig so bought the following off ocuk
Asus M4A88TD-V Evo/USB3 880G £94
WD 1TB Black 6/gbs OEM £72
Xigmatek Asgard Case £26
2x Samsung 22x Sata DVD-RW £26
Total £531
these are the parts i ordered for him as he wanted 2 ODD's which has bought the price up from £518-£531 but then when i had a good speak to him he didnt really want high end graphics card so i swapped it for the HD4870 512mb i had in my HTPC and refunded him £55 but for the time being iam sticking to the above spec just to see how much power you can really get for around the £500 mark so some pic's off the build its self
To start with the componants them self (you may noticed that a couple off things are missing ie graphics and cpu cooler as the gpu didnt arrive till today and cpu cool still has not turned up)
now a to start striping the case down for a budget case i was rather impressed with the quality off this and the tooless design has been slated but personally i found them better than the zalman one in the z7 plus build i done last week (http://forums.overclockers.co.uk/showthread.php?t=18187486) as they hold very tigh and are a very simple idea big thumbs up on that and the pci holders were worlds better than the zalman one as the ones in the zalman just kept coming lose so i ended up using screws in the end so her goes some pics of the case
the extras (lots of bits for cable managment didnt even get bits like this with my RV01)
now some off the case
internals are very well though out clips on the back cable routes in place and motherboard cpu retension bracket hole
now i started with putting the fans in (found a old akaska amber which i though would go well in this case) ODD's and HDD's then mobob with cpu and memory followed by psu
was rather impressed with this mobo very good packaage 2x 6gbs sata cable's and 2x sats cable ide and genrally a very good looking board only grip is the sata should be side mounted insted of faceing up but for £90 who can gruble lol (btw in the pic the mobo looks a kinda of black brown but this is due to the flash in person its a very deep gloss black)
never use a corsair psu was impressed with the packaging and the braiding put the unit it self felt a lot lighter and flimsy compared to my thermaltake toughpower 650w considering that these cost nearly half as much again but then again it has got a 5 year warrenty compared to 3
only waiting on the cpu cooler now
time to put some benchmark programs plus extra requested files and overclock it see how much perfomance can be got from this will update as soon as there complete
Total £531
) once you get the new cooler i'm sure that chip will go higher
