- 25 Jun 2008
- Bonnie Scotland...and sometimes Denmark!
Hello fellow modders and builder!
Upon finishing my MSc dissertation I have decided to relax by rebuilding my current system and add a few extra parts Ive had lying around for a little while now.
Current specs:
Intel Core i7 920 D0
Asus Rampage II Extreme
6gb OCZ Blade 1800Mhz
Sapphire ATi 5870
2x 64gb Samsung SSD's in RAID0
Some Raptors and some other data drives
Mountain Mods Ascension Duality: Black Wrinkle Powdercoat
Current I only have the CPU watercooled, thanks to the untimely demise of my 4870X2. However I now plan to add my graphics card and motherboard to the cooling loop which is the main aim of this rebuilding project
I know many will argue the effectiveness of adding chipset and mosfet cooling, but I am going for aesthetics as well. I am going for a blue and black colour scheme. Not original I know, but it works for me
I shall be using the following watercooling gear:
Laing DDC-1T Ultra
Heatkiller 3.0 1366 CPU Block
EK Asus X58 Mosfet Kit - Acetal
EK Rampage II Extreme Full Board Block - Acetal
EK 5870 Full Cover Block - Acetal
2x Thermochill PA120.3 - 25mm Spacing
XSPC UV Blue Dual Bay Reservoir
Akasa 120mm Blue LED 1600RPM case fans
Scythe Kaze Jyuni 1900RPM case fans
I am going for a single loop rather than dual loops, with the order of
Res > Pump > Rad 1 > CPU > Mosfets > Mobo > Rad 2 > GFX > Res
Tomorrow I will steal my mums camera and get some pictures up and make a start on taking my beloved system apart in preparation for the rebuild.
This is the first time I have attempted to log a project so please bear with me as I waffle on
Thank you!
Current specs:
Sapphire ATi 5870
Laing DDC-1T Ultra
Thank you!
