Current state;
This is my first attempt at watercooling. Going to be upgrading my old i7 920 to a i5 2500k in the upgrade too, rest is pretty much what i had before.
Build Components;
Project Black Ice
2 x HIS ATI Radeon HD 6950 IceQ X Turbo 2048MB GDDR5 PCI-Express Graphics Card £209.99 (£419.98)
1 x Corsair Professional Series AX850 High Performance 850W Modular '80 Plus Gold' Power Supply (CMPSU-850AXUK) £169.99
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £167.99
1 x Asrock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155) DDR3 Motherboard £159.98
1 x OcUK Tech Lab - D5 Vario Pump & Alphacool Clear HF D5 Top Value Combo £84.98
2 x Corsair Vengeance 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9) £67.99 (£135.98)
1 x EK Supreme HF CPU Waterblock - Nickel Plexi £56.99
1 x EK CoolStream Radiator XT 360 (120.3) £48.98
2 x Hardware Labs Black ICE Radiator SR1 120 - Black £44.99 (£89.98)
2 x EK-VGA Supreme HF - Nickel Acetal £38.99 (£77.98)
1 x EK Multioption Reservoir X2 150 Advanced £33.98
1 x Lamptron FC2 5.25" Bay Fan Controller - Black £24.98
1 x Mayhems Pastel - Raspberry Purple Coolant 1L £14.99
I will update this in a blog style day by day update in the first few posts.
Pictures will either be from my phone (easy to upload) or my camera depending on the necessity of picture quality.
Day One 28/11/11
Allready owned parts and GPU Blocks arrive
I am planning on leaving the L shape metal plates on as heat sinks. For me they look better than the little HSnks for the RAM. Went with the acetel blocks as the nickel/plexi were out of stock. They will be mostly out of sight and still fit in with my colour scheme.
Blocks going on
The instructions that came with the block are wrong, as it came with the easy mount kit. (not sure if all of yours are like that ocuk staff) so heres a link to the proper one if anyone else using these blocks ;
http://www.ekwaterblocks.com/shop/EK-IM/EK-IM-3831109805039.pdf
Blocks On
Well thats all i can do today cause of a late delivery.. Roll on Day Two!
Build Components;
Project Black Ice
Day One 28/11/11
Blocks going on
Blocks On
but awesome at that!
