Project black white and blue
29 May 2012
Dorset
Right guys just ordered a few bits from ocuk new case cpu and stuff here are the specs
2 - KFA2 GeForce GTX 670 2048MB GDDR5 PCI-Express Graphics Card
1 - Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor
1 - Asus Z77 Sabertooth Intel Z77 (Socket 1155) DDR3 Motherboard
1 - NZXT Switch 810 Big Tower Case - Black
2 - Corsair Dominator 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel
1 - NZXT Havik 140 CPU Cooler (Socket 136611551156775AM3AM2+AM2)
1 - BitFenix Recon Internet-Connected Fan Controller
4 - NZXT FN-140 Enthusiast Performance Case Fan - 140mm
Going from
A q6600 b3
680i sli mobo
8800gtx
4gb corsair mem
antec 900
will be swapping with me my ocz 720 modstream psu a sammie 830 256 a 1tb WD green drive and a sammie dvdrw
A couple pics of how it started
https://docs.google.com/open?id=0B_Z13Ld0I0ZKRHljLVlLelBKRG8
https://docs.google.com/open?id=0B_Z13Ld0I0ZKWENHOUtJZ2xTajg
Will update later when the boxes arrive
Well I put it all together and found my PSU couldnt cope due to its 4 15 amp rails and I was blowing one by running my 2 graphics cards so as has just arrived my new stupidly over powerful psu
http://www.overclockers.co.uk/showproduct.php?prodid=CA-054-OC&groupid=701&catid=123&subcat=1098
so I'll be getting some more pictures and hopefully at last a few benches up
Ok its taken a while to get finished had a couple issues with the memory and psu and ive not finished the cable tidying yet however here are some pics so far
I suggest the Noiseblocker 140mm fans instead of the NZXT FN-140, because the noiseblocker 140mm have just seven blades instead of nine blades, more blades increase the frequency noise of the fan and therefore the fan become faster noisy when you increase the speed, this is the reason the ventilators have just three blades
http://upload.wikimedia.org/wikipedia/commons/8/89/Ventilator.jpg
The blue went by the wayside so thanks to the psu change so its now just black and white
Will be doing some cable management on it soon, and also hopefully some water
Big on the outside but surprisingly not as big as I thought on the inside although much more room to work compared to my old antec 900 however it also feels cheaper then the 900 too the plastics just feel bit flimsy and too well plasticy its hard to explain. Its certainly no lian-li however for the money its big bold and good value
