OK, this my first venture into water cooling. I'm going to water cool my current right which is -
Special Edition White Graphite Series™ 600T Mid-Tower Case
ASRock Z87 extreme 6
OCZ 1000W ZX Series PSU 80+ Gold Rated Ultra Quiet Double Ball Bearing Fan
Corsair CMZ16GX3M4A1600C9B 16GB (4x4GB) 1600MHz CL9 DDR3 Vengeance Blu Memory
Haswell 4770k
Corsair H50
Shopping list -
1 x Cooler Master MegaFlow 200 LED Fan - Blue - replacing the front fan
3 x Scythe Gentle Typhoon 120mm - 1450 RPM
1 x EK Water Blocks EK-FC680 GTX SOC - Acetal + Nickel
1 x Alphacool NexXxoS NVXP Nvidia GTX680 - Brushed SS Silver
1 x XSPC RayStorm CPU WaterBlock - Intel 1156/ 1155/ 1366 and 2011
1 x XSPC EX240 Slim Line Dual Fan Radiator
1 x XSPC EX120 Slim Line Single Fan Radiator
1 x XSPC Dual 750lph Bay Pump Reservoir V4 - Black
4 x Monsoon 16/10mm (OD 5/8) Rotary 45° - White
1 x Monsoon 16/10mm (OD 5/8) Light Port Rotary 90° - White
2 x Monsoon 16/11mm (ID 7/16 OD 5/8) Free Center Compression Fitting - pack of 6
4 x Monsoon Accent Disc - Blue
2 x Masterkleer Hose Pack PVC 15.9/11mm (7/16ID) UV-Reactive Blue 3.
2 x XSPC - EC6 Non Conductive Coolant - UV Blue
1 x XSPC LCD Temp Sensor (Blue) V2 + G1/4 Plug Sensor
1 x Revoltec Cold Cathode 30cm (12") Single - Blue Rev. 2
2 x mod/smart Kobra SS 6pin PCI-E extension - White - 20cm
2 x mod/smart Kobra SS 8pin PCI-E extension - White - 20cm
1 x mod/smart Kobra SS 8pin 12volt EPS Power extension - White - 20cm
1 x mod/smart Kobra SS 24pin Motherboard Power extension - White - 2
Will upload some photos this weekend of the current rig, watercooling gear due next week - eeek!
Haswell 4770k
Corsair H50
Shopping list -
