So it's getting to that time of year where I've got cash to burn, that and I need to do maintenance!
Okay, I've no intention of upgrading platforms right now. I'm going to wait for DDR5 before I dump a ton of money into that. But there's several things that need to change and I'm hoping you lovely folks @Jay85 I'm looking at you pal, lol. Can help me get sorted.
Okay so the main issue I'm having at the moment is temps, I've got a 5ghz overclock on the cpu but have seen temps rise over the months. I'm now idling at around 81c so I've still got some head room but it's creeped up quite a bit. GPU sits at 61c idle and pushes 90c when under load. It's a hot box and with all the rad space I've got in there I feel I should be doing better. Finally another one of the uni fans have given up the ghost on me. The bearings on these fans suck!
So replacing the fans is a must, if anyone can make any suggestions on what fans I should go with please feel free. Also any other suggestions for getting, and keeping temps down would also be very much appreciated.
Next, I need to get this GPU under water (Gigabyte Gaming OC 3080) so suggestions on a water block for the card would be a huge help. I'll also be looking at swapping out the thermal pads on it as well, after watching a video on the card being sucky for mining as the VRM's get too hot, but also cause looking at the fans on card I can see the dreaded oil leak from the pads.
I also need to think about a fluid temp sensor, so I can set my fan curves to that.
Any and all suggestions considered.
It's either this, or I look at going back to air and saving a heck ton of cash! lol
