- 24 Feb 2009
- Teesside
that pumps ace! Is it just 2 Laing pumps with a custom double top thing? Never seen it done like that before
That is a great set up, you should get the case power coated.
Hehe, glad it found a good home
The cylinder res's do look so much better than bay res's tbh, now you just need a window and then you will spend ages just staring through it looking at your handywork![]()
Very very nice mate. You changed the clear/red coolant for black tubing on both loops right? Red is hard to get a nice solid color.
