It all started at Christmas when I got an Corsair Obsidian 650D mid-tower case, which got me by surprise. After looking it up I found it slightly too big and heavy to transport, in comparison of having an Antec twelve hundred case, I believe that I wouldn't be able to fill it up to it capacity.
Though we manage to exchange it for an Corsair Obsidian 350D instead, which is an micro-ATX version of the 650D. Which looks just as good, my brother has good taste but he figured that bigger the case the better. Now that I have a case, what to do?
Didn't really plan of making an computer, with little spare time. Ah well I went gung-ho and got the following specification in the end:
Motherboard
Asus Maximus VI Gene Micro ATX
CPU
Intel Core i7 4770K
RAM
Corsair Dominator 4x8GB 32GB, DDR3 SDRAM, 1600 MHz
GPU
Asus Radeon R9 290
SSD
Crucial C300 (Spare-part)
PSU
Corsair AX760i Digital ATX (RMA upgrade replacement
FAN
6*Corsair SP120 PWM
Watercooling:
CPU
EK Water Blocks EK-Supremacy - Nickel
MOSFET
EK Water Blocks EK-MosfetASUS M6G - Nickel (Original CSQ)
RAM
EK RAM Monarch X4 CSQ Memory Waterblock : Nickel Plexi
PUMP
Swiftech MCP35X PWM DDC 18W Pump White : MCP35XWT
PUMP-EXTRAS
EK Water Blocks EK-DDC Heatsink Housing - Nickel
EK-DDC 3.2 PWM X-TOP CSQ - Plexi Wa
RAD
2*EK-CoolStream PE 240 Dual
EK-CoolStream PE 120 (Single)
RES
EK-BAY SPIN Reservoir - Plexi CSQ
TUBE
Primochill PrimoFlex Advanced LRT Clear
FITTING
EK-CSQ Fitting 10/16mm G1/4 - Nicke
EK-PSC Revolvable angled adaptor 90
EK-PSC Revolvable angled adaptor 45
EK-Extender G1/4
Bitspower 1/4" Thread T Fitting
Bitspower Dual G1/4
ACC
EK Uni Rad Holder 120
Extra
Corsair Generation 2 Sleeved Cable Kit
Corsair 24 Pin ATX Individually Sleeved Cable for AXi 1200i / 860i / 760i (Gen 2) Red
2*Phobya two 3mm ultra-bright
1*Phobya two 3mm ultra-bright (sleeved)
3*Phobya two 5mm ultra-bright (sleeved)
Phobya External PSU 230V to 4Pin Molex 24 Watt including Euro/UK Plug
2*Flexa PWM fan splitter
Things that didn't made it to the build:
Corsair Obsidian 650D Case
Intel Core i7 4770k (Malaysia)
G Skill 2x 8GB PC3-19200 DDR3 2400MHz
MSI R9 290X
Koolance QD3 Male/Female Quick Disconnect
Corsair SP120 (Non-PWM)
EK-BAY DCP 2.2 Combo Unit - Including Water Pump
EK Supremacy PreciseMount Add-On Naked Ivy
The build is partly finished, due to work, holiday, unexpected purchase and etc... Will have to do some catch-up, with this log. Like all projects things did not go exactly to plan, it was meant to be "simple". This is my first water cooling attempt....
The beginning... *rewind*
Stupidly Asus Gene VI motherboard only has two PWM fan connectors, which is the CPU and CPU_OPT. I recommend getting an PWM fan splitter, so you can have more than two fans. Akasa PWM splitter can link up an total of 5 fans, which works with the Corsair SP120 PWM.
I've tried Corsair SP120 (non-PWM) but they run too high even on the lowest setting of 1340 RPM, PWM fans was capable of going lower with 706 RPM.
I'm currently using two splitters on each of the enabled PWM connectors, just encase I need more fans. But it does make cable management just abit harder...
Like with any stuff you buy, you must test them. I had a C300 laying around with an old system image, ran perfectly fine once it has detected the new hardware. Done memtest+ overnight, and loaded a few games.
Everything seems to be fine from this point, well I could have stopped here. Well I didn't.....
Motherboard
CPU
Intel Core i7 4770K
RAM
GPU
Asus Radeon R9 290
SSD
PSU
FAN
6*Corsair SP120 PWM
Watercooling:
CPU
MOSFET
RAM
PUMP
PUMP-EXTRAS
RAD
RES
TUBE
FITTING
EK-Extender G1/4
Bitspower Dual G1/4
ACC
Extra
MSI R9 290X
