- 17 Jan 2006
Hi All
I'm looking to sort out a side gate to give a bit more privacy down the side of my house and to make the passage way a more useable space.
Obviously on one side of the passage way is my house, the other side is a brick outhouse/shed belonging to the neighbours. I have asked about attaching gate posts etc to the brickwork and have been told that it's fine to do so.
The passage way is approximately 6 feet wide ands has a three foot concrete path running down it. The path is about a foot from the wall on the house side and 2 feet from the outhouse wall.
My plan is for a 6 foot x 4 foot featherboard gate to be hinged on the house wall and then to build a framework to fill the gap on the other side. I did look at a single 6foot gate but as they length of the passage where I am building the gate is only about 14feet long it would make too much of the passage unuseable due to the swing of the gate.
I have done a lot of ringing around to find somewhere that would make me up a gate as most tend to be 3 feet wide, and they are going to a) Cost a fair bit of money and b) take 3 or 4 weeks to be produced....
So, I'm wondering how easy/hard it would be to make my own featherboard gate??
I've done some googling and by the looks of things it 'should' be a fairly simple process (albeit a bit time consuming to ensure the featherboarding was straight and level etc).
Has anyone (who isn't a carpenter
) had a go at making their own gates and if so how did you find it??
you can make anything with the proper plans
