- 26 Dec 2013
- 404 Not Found
The purpose of this project is to create a secondary PC for gaming/general use and leave my current prodigy build for work use.
My prodigy build is going to be gutted and replaced with air cooling, and the water cooling transplanted with some new parts into the new build. The system specs will look something like the following;
Bitfenix Prodigy:
Asus Maximus VII Impact
Intel Pentium K Anniversary G3258 - Heavily Overclocked
Kingston HyperX 1600MHz 2 x 4 GB
R9 270X Toxic
Sandisk X110 120GB SSD
Corsair RM Series PSU
Bumble Bee:
Fractal Design Define S
MSI Z97 MPower Intel Z97
i5-4670K @ 4.2GHz (Maybe more if I can get it stable)
Kingston HyperX Beast 16GB (2x8GB) 2400MHz
GTX 970 (Mini ITX Version)
Samsung 840 EVO 250GB SSD
Fully modular PSU (To be confirmed)
I already own all of the above components, some I found in the box of spares (apart from the Sandisk X110 which I bought last week).
The colour scheme for the new build is going to be black and yellow. I am hoping to do hard acrylic tubes on this build using a little fittings as possible, so a lot of bending to do. Hopefully it will pay off and look amazing with some of Mayhems Pastel Yellow flowing through.
I will update shortly with the progress of stripping down the Prodigy and rebuilding with air coolers and replacement GPU.
Bitfenix Prodigy:
R9 270X Toxic
Bumble Bee:
But I think you made the same error as me with your cpu wb, you need to peel off the blue protective plastic over the EK logo
