Project : Bumblebee
9 May 2007
i entered WCUK 2009 modding competition but barely did anything because I was busy, anyway its been in my room ever since and i thought i gotta finish this project this summer. previous work can be found on my competition entry, but thier a competitor so i wont post link.
CURENT STATE OF CASE
as you can see i cut the lines between the holes on the roof making the grill, but i noticed this idea is stupid and going to fix it with a piece of aluminium. i also cut a hole next to where the PSU is mounted for cable management where all the power cabels will go through there and around the back hiding them. the window was cut and finished before i stoped working on it too.
as for the project i decided to go with project bumblebee (from transformers), i will be going for chrome/metallic black/metallic yellow color scheme.
http://z.about.com/d/onlineadvertising/1/0/A/-/-/-/bumblebee.jpg
plans:
1. cover up roof
2. mount hard drive bay horizontally
3. make front panel with acrylic
4. cut back plate hole on motherboard tray
5. mount radiator and pump on bottom
6. paint case
7. braid PSU
8. use shower tubes for sata and power sleeving
for now i got exams but when your studying and looking at a unfinished project you start to get carried away lol, so after exams i will be finishing this project but while doing my exams i just have small minor updates now and then.
im still looking for fans, water cooling parts and pc hardware to go in it so any one would like to donate any parts they dont need please contact me.
INITIAL IDEAS
ms paint
fix roof with a piece or alu which i will paint metallic yellow, front made from 4 layers of 3mm acrylic (yellow, black, yellow, black). hardrive bay will be mounted horizontally under 5.25" bays. initial mesurements show rad and pump can be mounted on the bottom.
new picture with the hardware inside.
small update 30/4/09
DCC pro 10w pump arrived today. i also cut off the useless parts off the HDD caddy ready to be rivited on.
also taken apart my sunbeam fan controller to be steathed later on.
update 02/05/09
well i was gona chuck away the floppy drive bay, but i found a better use for it
i cut them out with a coping saw, was so hard. then filed and holes where redrilled for a fan screw.
then i drilled some holes into the sides of the pump acrylic top and put a set of anti vibration kit on
da da..... mounted pump on the fan (not actual fan im using)
thumb screws are too short to reach the anti vibration kits when mounting the pump on. so i thought i use some old motherboard seperators to extend it.
Looking good :)
However you'll have to remove the link to the forums, since they run a shop which would be classed as competitors.
Haha have fun doing that! I saw the name of the project and hoped it would be transformers :D
update 02/05/09
this fan will be mounted on the front pannel.
small update: some suff came
my acrylic came
this actualy was bought long ago not 100% sure what to do with these quick disconnects
20m of 3mm braiding £10, bargin! and some black rivets :D
quick test of rivets and the paint on it seems to crack when used :(
dremel reenforced disks :D and my autobot logo came too, and wraped my braiding on a old wire reel.
30 gold tumb screws, some surge strips, white led fan, and 30m ethernet cable :D
fat yateloon fan :O and 3 normal yateloon fans for rad which i not getting no more :( xspc L dcc mount i dont need no more, and some hose clips i dont need no more. i told chilled pc to cancle the stuff when they said there was delivery charge problem on the site, but they sent me it anywayz. =.= o well i cba to send it back
anyway i got 3 exam next week so i cant work on this right now but will post update when i do get around it. still got a chrome autobot thing, and some black thumb screws comming
27/05/09
exams finished :D and my new pixon phone came, so better pics.
delta v3 came along with my phone
look at those pins :D
the universal mounting
i know i7 mount aint supose to be used like this but i thought i just put it in.
any way any one can confirm how to mount v3 on?
screw>plastic washer > motherboard > plastic washer > nut > universal mounting > plastic washer > spring > big nut
as i got it second hand i didnt get any instructions
forgot about some pics i took with my old phone
me he120.3 came, cost me £25 :D
also got this old D4 pump for £15, was so cheap i dono why i bought it maybe for a new build later.
the HE120.3 came with 6 fan gards, quickly sanded one down and soldered on my HDD rack so i can mount HDDs on the 120mm fan mount in front.
daisy chaned my yate loons and mounted, quick test and seems to work.
been playing with sketchup and seems i can fit a 120.2 if i wanted to infront.
