Man of Honour
- 13 Nov 2009
- Northampton
Right my Antec 300 is getting a little long in the tooth and water cooling in it is not easy while keeping the cables tidy.
This will be my first big Modding project other than the side window on my Antec.
I've decided to go a little Retro with an Akasa Eclipse that I've just got for £20, won't get it till next week though.
Hardware
AMD Phenom II 955BE @ 4ghz 1.45v
4Gb OCZ Spec Tops
Gigabyte GTS450 OC
Plans
Cut 240mm read hole in case floor. Possibly a 360.
Carbon fibre look mono tray using 3M Di Noc
Large window in the side panel
Water cooling
Laing DDC 10 - XSPX Plexi Top
XSPC Delta v3 - May carbon look the hold down plate
Ek 240 rad
XSPX RS 120
Phobya Balanced 150 black nickle.
Coolant will probably be Blueberry Blue Mayhems Pastel.
Hardware
4Gb OCZ Spec Tops
Gigabyte GTS450 OC
Plans
Water cooling
Ek 240 rad
XSPX RS 120
