Cheers for the comments guys :]
TehBlueBear - if you ever decide to watercooling, get some of these 10/8mm compression fittings. You just push the tubing over the fitting (it generally needs warming up as it's a tight fit) and then you screw down the cap, which 'locks' the tubing in place :]
Vlper/gt_junkie - cheers, I like it too :]
DampCat - LOL =p I was waiting for something like that ;] TBH, the pink doesn't look all that unmanly...I must admit I knew it was pink before I bought it, but the bottle says Feser One Red so that's always a get out close no? I'm looking forward to getting a black loop in there somewhere, the contrast should really set things off!
Anyway, onto the next update xD
Update: 24/01
It's All Coming Together
Update time! :]
First thing I did was remove the chipset cooler:
Ouch :/ The thermal stuff was literally flaking off. I cleaned it all up, put on some Ceramique, and installed my HR-05 SLI...
Then my camera batteries died =( Anyway, there wasn't anything exciting for the next 3 hours or so...I'll describe it anyway ;]
Fitted the HR-05 SLI
Tried to install XSPC Delta block with loop filled
Found that despite the manual saying "Tubing should be attached to the block" it is physically impossible to get the mounting plate over the block when the loop is filled...
Spent about an hour at 1am draining the loop with no idea what I was doing :]
Fitted XSPC Delta block with mounting plate
Reconnected up tubing
Refilled loop
Sorted out a couple of fans (you'll see what I mean :] )
Breathed a sigh of relief I hadn't killed anything yet
Switched on the PC
PC froze when I entered the BIOS
And again
And again
Repeat until I get the idea
I gave up, tried once more, it booted to Windows :/
Checked temperatures
60C and climbing idle
Checked watercooling loop
Realised pump wasn't plugged in properly, hit wallplug switch
Plugged pump in again
Booted into Windows, PC froze
Shut down, went to bed
Anyway, next day I came home and switched on the PC. It booted up for 5 seconds, making loud buzzing noises from the chipset, and then switched itself off. With the feeling the HR-05 SLI was the cause of my problems, I removed it and refitted the stock NB cooler, and no problems since :]
Anyway, onto the pictures!
My fans for the radiator - this is upside down =o The 'top' one in the picture is resting on the floor:
My complex fan mounting system...
Shiney block!
The pump all filled and in the case:
I connected up the blue supplied LED to the pump out of curiousity:
The water looks purple, it's very nice ;]
The crack I was worrying about has all but been covered :]
Excuse the mess!
That's a Zalman ZM-MFC1, just temporary - the fans on the radiator won't need a fan controller. I've sent Swiftech an email regarding getting some fan screws, and the yellow IDE cable is temporary...my DVD drive has died on me, I've connected up the other drive outside of the case now.
The bolts I've used for the 80mm to 120mm adapters are long enough to go through a 120mm fan as well, so when I get a minute the To-Do List is:
- Mount back 120mm fan
- Shorten tubing between pump and CPU
- Tidy up the wires (again)
- Mount the fans onto the radiator properly
Overclocking
Well, that's the cause of all this!
I'll start up a new thread rather than cluttering up this one, but I've noticed a drop of at least 15C xD
There is more to come, including watercooling my GPU with ANOTHER 120.2 radiator (that'll be fun!) and possibly changing this loop to 1/2" with black Feser One, and I'll keep updating =]
Ta for reading so far, just saying this stuff because I doubt I'll get a chance to update this for a couple of weeks or so - I'm normally wrong though =o
(Oh, and apologies for the MySpace style smilies used...I've got this log on a couple of forums so I tend to write the post and then post it up. The other forums all have >25 images a post so I go back and remove the smilies and it normally fits on here!)
