Project Corsair 900D
Crystal Link fitted and tested for an hour with no leaks:
P1030984_zps29c38de8.jpg~original
What it used to look like:
P1030957_zps36f9e387.jpg~original
You can see the mess if you look closely!
I'm a but stuck until my 900d arrives now!
The 480mm rads won't even fit inside my Level 10 GT!
And I can't fit even 1 of the tube reservoirs, so other than spreading the whole of my pc across the floor to run it, there isn't much i can do!
Disappointed! :(
Cant wait to see this!
I love those XSPC AX rads! They might be expensive but they look awesome
They do look fabulous! The build quality is excellent!
Still waiting on 2 rotary male to male connectors and an nzxt internal USB hub (don't have enough headers on my motherboard)
Which I believe are my last 2 parts... (I really hope so anyway)
I bought that hub recently, really great product.
All Revved up with no place to go.....
P1030993_zpsef61bacd.jpg~original
Crystal Links? It might be just possible that I over purchased on these:
P1030988_zps8d1b4fad.jpg~original
Motherboard tubing:
P1030986_zpsd81cb54d.jpg~original
P1030989_zpsd9c14765.jpg~original
P1030990_zps3086d45f.jpg~original
P1030991_zpsd90b24aa.jpg~original
P1030992_zps2ac4311d.jpg~original
Case Arrival time is between 12 & 1pm.... HURRY UP!!!!!
