Project cosmos S
4 May 2011
im starting this project thread so i can show you guys what i am doing, with regards to building my own PC. i have started building the computer its coming along slowly but surely.
started with my cosmos S case
added my coolermaster Aquagate Max got this on ebay bargain :D and a basic LG dvd / CD reader writer.
top mounted dual 120mm fan radiator
more parts arrived so got these fitted well only the power supply
didnt like the cosmos S side panel so i did some cutting to leave the metal mesh a bit more open.
so i have the following parts ordered and once they arrive i will get to work fitting them. and try and keep this updated as best i can.
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor
MSI P67A-GD65 Intel P67 (socket 1155) DDR3 Motherboard
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive
8GB corsair vengenance DDR3 RAM
sorry if this is in the wrong section couldnt find anywhere else to put it!
Parts arrived the day before my exam so as you can imagine i left them and went back to the books..... not i got to work building it right away! lol
got my waterblock added to the motherboard and tested was pretty happy with it
inside the case needs cables tidied i intend on doing this some time this week as well as a few other tweeks!
things lefts to do are
install UV CC lights any body have any advise?? i have the set of lights but dont no what to connect them to
cable tidy
move DVD drive below the watertank
get a blue ray drive
get a small screen
change my graphics card anybody want to buy a GTX 470 1024 HFA2 edition i think thats what its called.
also i have the system set up through HDMI and i have a logitech 2.1 sound system it there any way to run both of these together??
will update again soon!
