- 10 Jun 2009
- Darlington
Hiya guys,
Just thought I would post up here my latest scheme that has managed to rile the missus no end so hence the title
Well here is the start of my new build. Im gonna log it and post on here pics etc for some constuctive pointers.
Its older tech but still performs very well for me and my daily needs, so for now there isnt a need to massively upgrade.
Its mainly the parts from my old rig however im going with a new case and sli'd gpu's along with a lot more cooling ( 4 rads ) dual loop.
So for kick off the specs:
Rig Specs
Corsair 800D
Q9650
Asus Striker2 NSE 790i
2 x GTX 280's 1 x Asus 1 X Gainward
4gb Corsair 1600 DDR3 Dual Channel
1000w Psu
1 x 80gb Intel-M
2 x 150gb Velociraptors
1 x 1tb Western digital black
Cooling specs:
1 x Apogee GTZ 775 Block
2 x EK GTX 280 blocks
1 x XSPC 360 rad
2 x XSPC 240 rads
1 x Swiftech 120 Rad
2 x Laing DDC pumps
1 x XSPC Dual loop res
4 x Sharkoon Silent Eagle fans ( CPU loop )
4 x Asaka Viper fans ( GPU loop )
1 x Scythe fan controller
There are numerous compression fittings and at the moment 5m of Feser UV reactive clear tube.
The general idea for the layout is as this pic:
So the first thing to do was to mod the bottom HDD cage. Very simple to do. Just remove the 6 rivets in the front of the case with a drill and then with a little force push out the drive enclosures. I found that the top 2 rivets gave the shelf a little more support so I replaced them with some self tapping screws after the removal of the HDD cage to add the support back in.
Pics to follow!
Rig Specs
Corsair 800D
Q9650
1000w Psu
1 x 80gb Intel-M
Cooling specs:
1 x XSPC 360 rad
2 x XSPC 240 rads
2 x Laing DDC pumps
Pics to follow!
