Right, system pretty much built up and finished now! Still plan on going i5 next month, but need somthing in the time being so built it back up with the P5Q-E and E8500. Will give me a chance to compare temps and such this way too. I expect them to be better purely because of the better airflow from having a decent grill in the front.
Anyway, photos. And lets start boring haha, all the nuts and screws and things I bought, wanted to do this case right, all the little details too
Test fitting a few parts for the new loop
Sorting the loops out and fitting the GPU block. I decided to include the mosfets in the GPU loop in the end. Makes it a bit of a mess of tubing inside but think it would be the most even distribution for the loops really.
Naked card!
And in its new outfit
Still trying to figure out the best way for the last bits of the loop here. GPU loop sorted but the NB/CPU loop still needs a few finishing bits sorting.
And there, finally finished! Its one hell of a mess in there and did all this before connecting the front panel wires... doing it after this was pretty tricky haha
One loop filled...
Two loops filled
The purple looks pretty good here in my opinion... check out the photos later on to see it the morning after, looks well faded
The res's are at slightly different heights or there was not enough room for the tubing
System turned on, pumps working, fans spinning... all looking good! Apart from that gap in the front haha! Still need some elastic to bungee mount my HDD's in there, and also need to get my spare bezels, theyre in Sheffield and Im not back there until the 8th Oct! Excuse the blur, I have trouble taking photos with the flash off but they look better when they do work out
The obligatory close up shots of rad grills! People always seem to include them so here are my battered old ones! Need to get some new ones that match anyway
And after it taking so much time I wanted to get a photo of the 24pin cable... this is about as good as it gets haha. Wraps round the tubing which is leaving the bottom of the purple res
And just because sombody always asks to see the back too, my average cable tidy job
Pics of it this morning, check out how much more... watery I guess, the purple is. Its faded loads. And everybody moans about Feser leaving gunk, the pink is Feser and apart from dying my res its been fine. The purple is Primochill ICE and its left loads of gunk all round the waterline in the res
Not the best... And it doesnt glow under UV and its supposed to... Personally Im sticking with Feser from now on!! Also SATA power cable just hanging down... sorry, like I said, its not in use yet so just there temporarily until I get hard drives sorted out
And thats it for now! Still need to get the hard drives in there like I said, but on the whole I think thats pretty well done, and its a pretty thorough job! Every screw replaced pretty much, mobo screws, case screws, fan screws... everything lol. The PCI-E cables need work as mentioned in another post earlier, but they can wait, just need to buy and braid some extensions.
But yea, fully internal dual loops in a Lian Li PC7... quite a feat!
Hope you guys like!
