Hey guys, As I promised on my watercooling thread here is my build log
Before I start, after 3 weeks of waiting on the 3900X I jumped ship and went for the 3700X. Now I suppose the main reason was E-peen, other reaosn was trying to get into streaming and also doing work programming at home but really....who wants to bring work home lol. So I settled on this setup:
Project Empire: Darth Vaders Personal Rig
CPU: Ryzen R7 3700X
CPU Cooler: EK Velocity D-RGB CPU Block
Motherboard: Gigabyte X570 Aorus Master
Ram: 16GB 3600Mhz Corsair Dominator Platinum RGB
Graphics Card: Gigabyte Aorus Gaming GTX 1080 Ti 11GB GDDR5X
GPU Cooler: EK Waterblocks Nickel/Plexi Block for Aorus 1080ti
PSU: Corsair AX1000 - 1000W Titanium Rated PSU
Cables: Cable Mod kit for Corsair PSU's (Black & Red)
OS SSD: 250GB Samsung 970 Evo M.2 SSD
Storage: 1TB Samsung 970 M.2 SSD + 1TB Samsung 850 Evo SSD + 2TB Seagate Barracuda HDD
Case: Corsair Crystal 680X RGB High Airflow Case (Black)
Fans: 3x Corsair ML120 120mm & 2x ML140 140mm RGB Fans + 3x LL120 Fans
Fan Controller: Corsair Commander Pro Fan controller
Radiators: EK Coolstream SE 360mm + 240mm Slim line Radiators
Pump: EK 140 Revo D5 Resevoir / Pump Combo
Coolant: EK Cryo-fuel Blood red
I thought I'd do the whole youtube show piece with my items before I started, I added in some Corsair boxes to complete the corsair fanboy look, these were gifts for Christmas and birthdays, i had a corsair strafe keyboard so when I decided I wanted less bloatware and multiple programs to control LED's and fans I decided Corsair Icue will be the way to go. So I call myself and accidental fanboy haha, I like their products and haven't had a bad experience yet but there is always time.
As a side note, I'd like to thank the OCuK employee who gave me all this:
Lmao
So I took a aprt everything to see if things would fit, also to move the fans around as I will replace the 3 front LL120 fans with ML120's and use the others elsewhere.
It's a fairly spacious case and I love having this secondary compartment as well.
Started moving the fans and checking rads:
And heres where the issues started!
I ordered a 280mm Standard radiator and a 360mm slimline radiator as using a configurator told me these were compatible. However after not looking at the boxes properly and opening them up I soon found that OCuK were kind enough to send me a free upgrade:
This is an EK Xtrreme overclocking rad and clearly not a slim one! The 280mm Rad was also already opened and missing the screws its meant to come with!
So I had to RMA them and order the slim one, which wasn't a hassle with OCuK, lukcily I had funds to buy extras and wait on the refunds to come through. Before I packaged up the 280mm I test fitted it and seen thast I might have an issue with that one fitting as well, so As a precaution I ordered 3 rads in total, A 240, 280 and 360mm all slimline rads to cover all scenarios just in case and would return items that I didn't need as discussed with an OCuK employee on the phone, at this time I wasn't aware I'd have to cover return shipping costs for "unwanted items".
So i did indeed find that even the 280mm slimline would not fit in with the 360mm, no matter which way I oriented the 360mm ports top or bottom the 2 rads would not fit once one was screwed in, so it had to be a 240mm at the top instead. I knew there would be issues which is why I planned for this, I'm not too disappointed in using a 240mm rad.
Took a look at the PSU as well before mounting it. Comes with these lovey magnetic strips to go with a colour coded build which is nice, limited but thankfully mine is a black and red Sith design. I chose this AX PSU over something like the HX1000i as I doubt I'll really need the digital interface (yet) and I can already control fans through corsair software, the titanium rating is also factor of course and the fact its based of a Seasonic design, which are frankly some of the best PSU's around.
Whilst planning this build I fell in love with the case, but the case is designed more around airflow but.... it can still house an open loop and the configurator shown me the pump would go in the secondary chamber, a bit of a bummer as you can't show off the RGB Res but it will add some back glow to the machine and in the end It's going to work all the same! I had to bugger around where to place the Reservoir it wouldnt fit where the config said it would...so this was my second issue. I ended up McGyver'ing it to this place.
Now, whilst this isnt the right mounting place and the holes I've clamped too are just to allow passive airflow at the front of the case it was near enough the perfect size for the standard bracket/clamp that comes with the pump. So here it lives!
CPU: Ryzen R7 3700X
Lmao
