Based on a Thermaltake P5 design open air case, my new build will be based around a Haswell 4770k set up which i already have.
First issue is the Msi Z-87 G45 gaming mobo i already have is Red, and i want it to be blue..... i will be using a custom Pastel liquid which i will be mixing myself so it matches the cables i have already purchased.....so i need the north and south heatsink bridges to be blue.
I have got the case and purchased a quad Alphacool nexxus Monsta 480 Rad which i also have received.
I am also using Acrylic hard tube with 16mm tubing and black compression fittings.
I have most of the parts now....just waiting for the Alphacool compression fittings and some light blue vinyl to arrive....gonna do some measurements tomorrow and order some perspex and leds.
I cant watch build logs as it makes me want to upgrade.
