Project: Eris
6 May 2015
Project: ERIS - Z170, In Win D-Frame Mini, H2O [Build Complete]
Introduction
Welcome to project Eris. Eris is the Greek goddess of chaos, strife, and discord.
The previous Darwin PC project, Erebus, was a Trifire R9 290X, X99, watercooled Corsair 900D behemoth featuring two 480 mm radiators.
Eris will be an ITX build based in the In Win D-Frame Mini, so on a different scale. The emphasis will still be on watercooled gaming performance, but this project will look very different.
The hardware is based around the new Intel Z170 chipset, with MSI's Mini ITX offering for the mobo and a Skylake CPU. Paired with a MSI Gaming GTX 980 Ti, Eris will pack a punch.
The project will be fully watercooled with a rigid loop, and I'm planning several mods to make this build something special.
Hardware
  • Case: In Win D-Frame Mini (limited edition red anodised)
  • Motherboard: MSI Z170I Gaming Pro AC
  • CPU: Intel Skylake
  • GPU: MSI GTX 980 Ti Gaming 6G
  • Memory: Corsair Vengeance LPX 16GB
  • PSU: Corsair HX750i
  • Cabling: Custom-sleeved with E22 Teleios
Watercooling
  • Radiator: Mayhems Havoc 240
  • Pump/res: EK-XRES 140 Revo D5 - Acetal
  • CPU block: EK-Supremacy EVO - Nickel
  • GPU block: EK-FC980 GTX Ti TF5 - Acetal+Nickel
  • Fittings: EK-HDC Fitting 12mm G1/4 - Elox Black
  • Tubing: E22 Custom 12/10mm Ultra Clear Hard Tubing
  • Coolant: Mayhems X1 red / aurora
Confirmed sponsors
Thanks to the following sponsors for making this project possible:
Updates
  1. In Win D-Frame Mini
  2. MSI GTX 980 Ti GAMING 6G
  3. MSI Z170I Gaming Pro AC
  4. Corsair HX750i PSU and Vengeance LPX RAM
  5. EK Water Block and backplate for GTX 980 Ti
  6. Custom motherboard tray
  7. Custom IO shield for motherboard
  8. Custom watercooling loop
  9. Custom cabling
Build complete
Damn, that red is amazing, what an awesome looking frame...
I remember Erebus well so have high expectations of this build ;)
Thanks to MSI for supporting Project Eris. First of their products is the graphics powerhouse, the GTX 980Ti GAMING 6G. The Twin Frozr V is a really nice looking cooler. This one however will soon be replaced with a water block...
The Z170I Gaming Pro AC motherboard from MSI. This mini-ITX board will be perfect for Project Eris. The styling of the new Z170 boards from MSI look great. It also comes with a handy M.2 slot underneath. Looking forward to modding this board!
Crucial M.2 fitted underneath the mobo:
Thanks to another sponsor for supporting custom gaming PC, Project Eris with these components.
The PSU is a Corsair HX750i, which will provide plenty of power for the system. It’s also fully modular and has few double wires, which will be helpful when sleeving the cables for Project Eris.
The memory is Corsair Vengeance LPX 16GB (2x8GB) DDR4 RAM at 2400MHz. The Corsair Vengeance LPX RAM is both fast and good looking, and the red colour matches well.
As the only colours in Project Eris will be red and black (with minimal silver), the RAM was modded by removing the info and yellow logo stickers. This was done with an X-Acto knife and a steady hand.
As shown installed in the MSI Z170I Gaming Pro AC motherboard, the colour matches well the heatsinks and design.
It's beautiful build! Waiting to see more.
Cheers :) more very soon!
Did you edit the red in the images, they look like "super red" !! I like it :D
Thanks - you don't think it looks overdone then? I think I actually had to lower the red saturation if anything. I've been playing with a new backdrop and lighting in my mini studio, and it still needs tweaking a bit.
Looks very nice! I'll keep an eye on this :)
Thanks a lot :)
The frame looks great but the red for the ram looks odd but I think because the further away stick looks a different shade to the foreground. I was just curious though I'm not critising. I really like the look of these frame case builds. Will be following....
I think I see what you mean, it might be partly due to the reflective surface of the RAM, one side looks quite different to the other. Thanks :)
Wow, lots of excellent progress since I last checked in, looking really good.
Still can't get over the red colour on the frame, looks fab!
Thanks for your comments. The frame is still probably my favourite part, I was pretty chuffed when In Win told me they had one of these limited edition anodised finish ones from Computex, apparently only 50 or so were made and they were never retailed. :)
