No, not for the win.
ForTress Watercooled!
Anyway, hi guys. Just ordered the first three things for my project:
Asus Maximus 4 Gene-Z
Coolermaster 650w modular PSU
And, the most important part of this build:
Silverstone FT-03 Black.
Already decided on how the case will be set up
for now I will have the rad and pump external to the case, until I can get hold of a dremel anyway, and will soon be getting a DDC with a tube res. Will hopefully be doing more dremel work to the case - fitting the 240mm rad, fitting a possible 200mm rad, custom side window and name.
Existing parts - i5 2500k
GTX 580 with EK full cover block
XSPC Rasa CPU block
XSPC RS240 rad
Samsung F3 1TB
2TB HDD
Crucial C300
XSPC 750 pump/res.
Well, this should be fun
for now I will have the rad and pump external to the case, until I can get hold of a dremel anyway, and will soon be getting a DDC with a tube res. Will hopefully be doing more dremel work to the case - fitting the 240mm rad, fitting a possible 200mm rad, custom side window and name. Existing parts - i5 2500k
XSPC Rasa CPU block
XSPC RS240 rad
Samsung F3 1TB
2TB HDD
Crucial C300
XSPC 750 pump/res.
