- 13 Apr 2010
- Sunny Sussex
My BMW F650 is off the road from now for a bit, I've got my MOD 2 mid next month so I need to complete before then.
My list of stuff to do
Put final baffle in = small welding shop down road welded in two captive nuts and gave me two allen bolts, sound much better with no spitting and barking when I slow down
Fix overheating = bridged fan for now is OK and await BMW to order a new
fan switch
Check oil = Ordered dipstick from BMW, original was swapped for oil temp guage with no marks, nice not, also the most complicated way of checking oil
Screen cracked = ordered a PUIG touring screen from Germany, about 12" taller, have fitted but is slightly bigger so doesn't sit properly, need bodging
Rear lens wobble = stripped down but the bolts have rusted up and need tightning, might need to find another somewhere
Rust = strip levers, stands, pegs, peg holders, crash bars etc for powder coating, just sitting in a box ready to be picked up
Rust = sand down bits can't get powder coated and paint hammerite smooth
Wheels = polish out pits, something to wait till all assembled
Rev counter = replace bulb might have a look at LEDs
Indicators = ones smoked so find another 3 or find 1 orange, don't know yet
Rear number plate = has been burnt by rear pipe so find another in pressed metal, where I don't know, the usual suspects don't do them
Plugs = old ones are rusty, surelyt time for a change
Pegs = old rubber ones are tatty, order new ones or look at something different
Datatag = has been but no paperwork, find out what the plan is
Handle bars = nothing really wrong with them and I didn't like Renthal on my bandit, investigate
Bit of a wish list as when I pass MOD 2 I bet i won't care about the little bits, I've stripped down so photos would be a bit pointless but when it's assembled I'll take some decent ones
fan switch
