Hi, I havent been a member of OCuK for that long as most of you have but i have found inspiration off this forum to create something of my own the no-one else has, Hopefully this will work, it isnt a huge Mod but im hoping for some help in Creating it, luckily i have a friend who is willing to help me install the new watercooling components.
What i intend to do is turn my PC into a watercooling setup but i want to mod the case to my personal preference.
Case is currently a Lian Li PC-7, i plan on installing a custom watercooling system with 1/2" tubing and EK cpu block, i intend on expanding the comp to watercool a G92 when released but for the moment it will be just a CPU loop but ready for expansion.
the watercooling setup i want is sort of like this but cpu maybe change to d-tek for when i upgrade to x38 motherboard.
EK-Wave LGA 775
Yate Loon D12SL-12 120x120x25 (2)
Tygon 3603 1/2" Tubing (5 Meters)
Nylon Hose Clamps 16mm - 19mm (12)
Laing DDC-1 Ultra 18watt Pump with Plexi Top
Black Ice GTX240
Repack Cooling Slot In Black
F1 Water Anti Corrosion Liquid UV Yellow 1ltr (2)
Danger Den G1/4 to 1/2" Hose Tail Hi-Flow Barb (8)
im planning in putting the Rad ontop of the case with the in/out pipes leading through 2 seperate loops that i will drill through the top, Pump will sit inside the case where my HDD cage is at the moment.
any help is appreciated. Sinny.
EK-Wave LGA 775
Black Ice GTX240
