OK mega update !
I got it down around 7pm last night. Put it back into one piece.
Fit the PSU
Fit motherboard and cooler.
Mount cooler. Ross, it did have plenty of clearance in the end. Now it has more airflow haha.
Cut oneself, get blood everywhere.
Mount top intake fan.
Just a quick note here. The 92mm fan has to come out. The GPU is bigger than it says it is. It does fit, but not with the fan, and it comes out of the front of the metal as I suspected it would.
Any way, moving on.
This bit took some serious measuring. I wanted the hubs (fan and RGB) in the top. I had to snap out a piece of plastic inside the top but it worked. I then measured it all out, stuck them together, mounted them and etc etc. There is space behind it to put all the wires. Well, once they are tidied etc.
And then a loose fit of the top to make sure it works. It does.
And the day ends at 11:55PM
However, going back in time. Before all of that I mapped, designed and created the new power button PCB.
That should be done by tonight I hope. I can then fit the front.
