- 28 Aug 2011
- Glasgow, Scotland
Ok, so i was asked to do a clean out by the missus.......i came across an old pc and was thinking after reading these forums for the last 2 days solid and being Wow'd by a lot of it, i was thinking i may keep the components and do something with them.
I continued to empty the loft, i found a set of monitor speakers that i used for my Dj equipment......i then thought, has any1 ever made a PC case out of a set of speakers.
The missus went to work so i took the kids into the garden and started to work. She is due back in 45 minutes and i have abandoned everything still left upstairs in a heap and nothing else attended to......its ok though i have a cumfy couch xD.
____________
pentium 4, 2gb kingston ram, 8800gt, 40gb HDD, 80gb HDD, 400w power supply.
on the last photo u see the PSU is outside, this is because the 24pin cable is too short so i need to get an extension......also u see that one of the fans LED is not showing, this is because i need to get a female to female molex so i can fit in another 4pin to 3 pin for the LED cable. Also needs a bit of a clear up on glue etc.
once i fix these errors i will post more pics or even a video of it up and running.......i also found some laminate so i may wrap it in that lol.
i have spent no money on this mod as i had the paint, cables and fans.....i will have to spend a couple of quid on 2 cables to get the PSU inside, i also have an external DVD.
not up to most of your guys mega sex wee PCs but yeh, Enjoy......
____________
