Hi I am a big fan of both killzone and Mnpctech so I wanted to try and make a custom case of my own...
I loved the side panel design that Mnpctech used on his D9 case and though I would try and re-do some of the design on mine but try and make it more killzone than D9 themed... (I really hope Mnpctech don't take it the wrong way, as I look up to them as a peers and I don't want it to seem as tho I am just copying...)
Case used: Antec 300
Tools used so far: Jigsaw/ Dremel/ Drill/ Sander
Meatrials used: MDF/ Body Filler
still have a ton of work to do... will update once I have more done...
