I've always loved this case when I bought it from OCUK back in Christmas 2006 that I have now felt it needed some 2011 updates. Lot's of inspirational ideas from million-dollar-pc.com that spurred me on to do this.
Some of todays cases never seemed to appeal to me. They all seem to have the inside silver, too big, too much plastic going on and such. Plus for some reason I've always loved the BTX layout. I still can't take to all the cases with the CPU at the top.
I can't seem to let go of Lian Li either, less is more?
The case originally looked like:
http://www.silentpcreview.com/article632-page2.html
Mods:
Roof cut and mesh for two 140 PWM fans.
Front cut and redone with mesh.
CPU back cut out.
4 extra holes made for better cable management.
Interior painted matte black.
Hard drive cage and side exhaust 120MM fan cradle will also be matte black... (not pictured yet) though I'm thinking of applying carbon fiber decal to the fan cradle.
I think I may take the power buttons back out to decal up the silver holder black...
My only dilemma is the door... it just doesn't seem sleek enough with the silver border edge... wondering if I should go all black... it just seems to be too much silver.
There will also be a mesh cradle that's going to be mounted in the drive bays for two 120MM Sharkoon 2000rpm fans that will be hooked up to the fan controller. Yet another smaller mesh cradle to sit in front of one of them for the Corsair H70 radiator.
Below that some sound dampening material to take away any vibrations.
Plus other mesh bits to be added internally for added styling.
Airflow should now be like:
Mods:
CPU back cut out.
