Project: Lian Li PC7²
Caporegime
6 Dec 2005
Birmingham
So im going watercooling again and I thought I would make a log of how everything goes, with lots and lots of pics inc my very special case thats in the works. :)
Any way onto business.
PC Hardware:
CPU - Intel Q6600 G0
Motherboard - DFI Lanparty LT X48-T2R
RAM - 4Gb OCZ 6400
Graphics card - BFG 8800 GTS 512mb OC (may be changed to a PNY 9800GTX soon)
Hard drives - 250Gb Seagate, 500Gb Samsung, 2 x 60gb 2.5inch (Fujitsu & Seagate)
PSU - Corsair 620W
Watercooling gear:
CPU block - EK Supreme Acrylic
Pumps - D5 Vario, D-Tek dB-1
Rads - 1 * Thermochill PA120.2 & 1 * Thermochill PA120.3
Res - 2 * Swiftech MCRES-Micro
The bottom of the res have been modded so the out let of the res is at the bottom. Can then put the pumps directly below the res, makes everything a lot easier.
Coolant - Feser One (Yellow & Purple)
Case - Lian Li PC7²
Some latest pics of the case...
Custom *competitor* PA120.2 backplate goodness. :)
Second rad will go in the top panel of case.
Right case for PC and left for watercooling etc.
Cases are attached together using some metal spacers so that both front panels can still fit on.
Thats all for now folks.
Looks nice, can I ask why you're using a 680i board with an ATi card, surely you'd be better off with the increased overclocking/performance from using an Intel chipset as you're not going to SLi?
Got the motherboard waterblocks for mucho cheapness. Plus 3.6Ghz is enough for me. :)
Woah, thats a lot of pictures! :p
With that much space I'd be tempted to try and find some stupidly large resovoirs. I hope you're gonna put a nice window on the side to show it all off!
PK!
PK!
Couple of EK 150 res's will be used. Just trying to find an ideal position for them at the moment.
There will be a nice square window.
Pity to leave what will probably be the loudest of the components on air. Will you be going for WCing the 3870X2 once a waterblock for it is out?
Its quiet to me. :p
I may do but the EK block costs £83 at the moment and im not paying that much. Plus I change graphics card way to often.
Though I may if something happens. ;)
A few changes...
Going for a PA120.3 (bottom) and a PA120.2 (top) and getting two Swiftech MCRES as it will be easy to find a decent a place them.
Sorry for the very late update but I sort of broke my knee playing basketball and my right leg is in plaster from groin to ankle. :(
Hopefully have the case next week. Only problem is though i left a pump and coolant in my uni room but thats no problem really.
Another thing is that im no longer going with the 680i board with watercooling mobo as me and Colossous (dont think he is on here but some of you may know him form other places) have been dealing again. ;)
Will update as soon as any other news comes in.
