Project Meticulous - Dual Loop Thermaltake Tower 900 Build
22 Jul 2015
Aberdeen
I am going to start a new build. Always wanted to build into one of these massive cases and now is the time. Here is the link to the case. Obviously it will be a watercooled hardline build with dual loops.
Hardware List:
Case: The Tower 900 Snow Edition E-ATX Vertical Super Tower Chassis by Thermaltake
CPU: Intel® Core™ i7-5960X
RAM: 32GB Corsair Vengeance 2666MHz DDR4 (4x8gb)
Motherboard: ASUS X99-A II
GPU: Nvidia GeForce GTX 1080Ti
PSU: SuperFlower Leadex GOLD 1300W Fully Modular "80 Plus Gold" Power Supply
Cabling: Sleeved cables to match the build theme.
Storage: A combination of SSD's and HDD's
Watercooling loop:
Coolant: Mayhems Pastel White with dyes to match the theme build
CPU Cooler: EK Water Blocks EK-Supremacy EVO
EK 1080Ti full cover GPU Block
Reservoir: Custom build
14/10mm Acrylic Tubing
560mm Hardware Labs Black ICE Radiator SR1 560
360mm Hardware Labs Black ICE Radiator GTX 360
I have the case now but instead of doing photos myself, this animation from Thermaltake will be more useful in demonstrating the capabilities of this case. Gigantic case really.
I love dual loop builds! Can't wait to see yours. If I were you, I'd make it extra special by mixing my own colours. Get the white pastel fluid, and then add dyes.
That's the current plan but I am also considering the use of distilled water with biocide and dyes.
I'm pretty sure Mayhems dyes, as well as Mayhems pastel mix, contain biocide already.
Ooh, you know what you should actually do? One loop pastel green, and the other loop transparent purple. I don't think I've seen a system that mixes opaque and transparent loops. If you added UV reactive to both, you've got a hell of a look going.
This is assuming you were planning to do green and purple. I would almost rather see pastel purple / dark transparent purple, or sky blue pastel / transparent cyan.
Things to think about, I guess.
I am talking about biocide only if I use distilled water with dyes for a transparent look. I am actually inclining towards that option. Otherwise Pastel comes with all the additives so I need not to add anything to it other than dyes.
Nice idea, please use a less offensive to my eyes project logo :D. Free of charge made for you... Use away, to stop my headache hehe.
The reservoirs are finished. Made out of 5mm clear acrylic. Dimensions are 41cm x 5cm x 5cm. Liquid capacity 0.7L. Used the right size drill bit and tap to make G1/4 fitting ports.
This is the basic layout of the build. I have taken out a lot of stuff from the case to make space for a custom base. Working with acrylic sheets to build everything now.
