Project: Mini Me
30 Nov 2012
-RESERVATION FOR PROJECT-
Having built my mini itx build (built in the states then lugged back here) and then realizing i forgot my fan controller, and my 200mm intake fan i shall be tearing my rig apart tomorrow.. and since i didn't get a chance to do an original build log i'll just do it second time round! anyway onto the parts and peripherals used in the build!
Your Basket
EVGA GeForce GTX 670 FTW
Intel Core i7-3770K
OCZ Vector 256GB SSD
ASRock Z77E-ITX Intel socket 1155
Corsair Hydro H100
Corsair Enthusiast TX750 750 Watt PSU
BitFenix Prodigy Midnight black
Corsair Vengeance 2x4GB 1866mhz DDR3
Cooler Master 200m MegaFlow
Subtotal £1,246.90
£1,039.08 ex VAT
Peripherals:
https://www.overclockers.co.uk/showproduct.php?prodid=MO-070-BQ&tool=3 -BenQ XL2411T
Razer Deathadder 3.5G
Keyboard not ordered
I know the layout is a tad messy (a tad huh) but i just plonked this down as a reminder to actually record my build! thanks and check back for when the photos are up!
P.S. For the change of products in my signature i had to pick parts relevant as i couldn't find them on OcUk
Can't wait to see the pictures! Your sig is wayyy too large by the way. See the FAQ here.
When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you.
