- 24 Sep 2008
- St. Neots, cambs
Welcome to the beginnings of my new project that I have yet to name. I have decided to change cases from my trustly old bitfenix colossus to the Coolermaster CM690II White edition. I wanted a smaller case that had support for 2 240mm rads without having to cut the case to bits!
Here are some teaser shots
Everything has fitted in nicely and there certainly won’t be and empty spaces once I have finished. Just need to decided on where to place my pump and then plan the loop order. My only issue is finding a fan controller , it needs to be either white or the same finish as the XSPC res cover otherwise it will look out of place. I have yet to find anything that will match so am very open to suggestions otherwise I might have to get a black one and mount it inside the case somewhere.
Tony
Tony
