Project Niagra
Man of Honour
30 Oct 2002
Surrey
Ok, well all the parts have arrived. This is what I've got and the plans:
System #1:
B3 [email protected] in a mATX case watercooled with a Swiftech H20 120 Compact Kit
Plan #1:
Switch the B3 for a G0 or a X3210 (see which is happiest) Its stable at the moment at 3.2Ghz but could do better I am sure.
System #2:
E6420 @ 3.33Ghz in a Coolermaster ATC 201 air cooled with a Thermaltake BigTyp 120 VX
Plan #2:
Use abandoned Asetek watercooling kit from FX51 that used to live in this case. This watercooling was never unpacked. Cut hole, mount radiator in roof of case, get 775 compatible waterblock. That should do it.
System #3:
Currently a AMD X2 4800 939 in a SN25P shuttle
Plan #3:
Basically a new machine :)
New Case, new mobo, new CPU, either Q6600 G0 or X3210 (see system #1), new RAM, PA120.2 RAD, chipset and CPU watercooling. This is going to be my desktop system so I want it cool and fast, oh and looking cool too :D
Case is to be a Lian Li PC-A16B and I reckon I'll need to mod it some to fit the rad in the front of the case between the drive rails. It won't fit in the top of the case as its too long.
