- 2 Jul 2012
- Berkshire, UK
Hi,
I've not posted my build on here before so I just thought I'd show you how it is right now. This is an ongoing build and I'll update this thread as and when I do any upgrades or make any little changes! It's been in this form for about a month and I'm pretty happy with it right now, although I'm strongly considering a GPU upgrade or a 21:9 monitor.
Current Spec;
Intel i7 3770k @4.4Ghz (Cooled w/ Enermax 120x)
8GB Corsair Vengeance Pro (1600MHz)
MSI GTX 770 Lightning
Asus Maximus V Gene
Seasonic G550
Samsung 840 128GB Evo
Seagate 1Tb Drive
A slightly annoying assortment of Enermax and Fractal fans
Peripherals;
Silly Membrane Keyboard - This definitely needs an upgrade
Logitech G500
Dell U2312HM
Philips Fidelio X1's
Fiio E10K Digital Analogue Converter
G500 is getting a bit tired.
Audio Upgrade:
A few months ago I decided I needed a bit more hight quality audio in my life so (after many, many hours of research and reading the X1 thread on here) I picked up some Philips X1's. I ran them with the onboard audio for a while before picking up a Fiio E10K DAC - this makes such a difference. The DAC made it sound like someone was holding a thick blanket over some hypothetical speakers beforehand (only way I can think of to explain the difference).
Thanks guys.
Current Spec;
Asus Maximus V Gene
Seasonic G550
Seagate 1Tb Drive
Peripherals;
Logitech G500
Dell U2312HM
Audio Upgrade:
Thanks guys.
