Project OMG, how big?
Caporegime
24 Sep 2008
Essex innit!
I was bored with my system and decided I wanted a new build and this is how it looked.
Secondary PSU was for clean power when benching my Titans, as it required a fair amount of juice. Plenty of dust and I just couldn't be bothered to clean it knowing I was going for a new build.
The old Switch case was nice but all a bit cramped and I wanted to go from 360+240 rads to 480+360 and I bought the XSPC H2 case/480 rad off Tonester. Nothing special in the build and just using a pair of Titans - 3930K - 16GB Avexir 2133 ram - Asus RIVF - EVGA G2 supernova 1300W.
It went like this.
This is the start with just the PSU in and mobo being in. That was nice and easy :D
Next up, it was a nice easy case of connecting fans to the rads and rads to the case. Plenty of room to work, so no issues here.
I decided whilst the computer was being rebuilt to redo the TIM on both GPUs and I thought I had missed off some thermal tape from the VRMs but I hadn't. Still, nice to have new TIM :)
Pipe fitting time and again, nice and easy. So much room to work, it was a pleasure.
Leak testing time.... No probs :)
I had some red and purple Mayhems left over, so decided to mix that with the De-ionized water and it is a nice pink (my feminine side likes).
No leaks, so time to start connecting drives. 2 SSDs (1x480GB and 1x 120GB - 2x2TB and a 500GB mechanical drives)
Everything connected and on testing everything, I have lost sound for some reason. Can't seem to get it back either so pretty miffed at that but does look like a fail on the onboard.
And finally my most hated job....Sorting cables out. I used duct tape to secure the cables and will be a pig to change but I will worry about that at that time :D
All done. i have 2 sets of PCI-E braided blue cables but can only find one set. I will have to look down the shed with all the other crap but for now, red will do. All in all, I am pleased with it.
Took me around 10 hours moving and cleaning everything up and about 5 hours to do all the cable tidying.
no nothing special at all.:rolleyes::D :D :D :D very nice build indeed
As someone working with an XSPC H2 atm... the lower support bracket for the mobo tray is missing... did you get a small right angle bit with two hole on one side and one on the other?
Yer, I added it near the end. I think this is what you mean?
Just to the back right of the force SSD.
Cheers T and great case. As for another Titan, I am sure it does. Great pressure and the fluid soon shot round and watching the air bubbles spin lets me think it would.
Yer it is but empty it is so light and half the weight of the switch. When it was all built and filled it was back breaking heavy though :D
The H2 is super light, (at least much lighter that my CM Stryker) but it is large. My suggestion for moving something so large, is don't :P
But seriously thought, I can only imagine how much my new build will weight, but if you follow normal heavy lifting health and safety, you will have no issues.
@Gregster can we see the other side of the case, Im intrested in the bottom tray.
Looks really nice gregster. Is the avexir memory you have the led ones as I'm thinking of getting that when I upgrade. I'd hate to think how heavy it is my rig in my build log weighs an absolute tonne and it's only 2 x 240 rads and less than a litre fluid. How much coolant does yours hold?
Blimey when you look at all the parts you think it's going to take a lot of fluid to fill it but ends up not needing much at all. This is a system that does actually hold what you think it might. Is it true what I read in places that that size of rads makes a cooling difference but on 2 identical loops if one had a 500ml res and one had a 20 litre res the max temp would be the same just would take a lot longer to reach it?
Yer, that is pretty much spot on. It is more about the fans working well in truth.
