- 25 Mar 2009
- Leeds, UK
After several weeks of top notch thinking I've gone with the Coolermaster ATCS 840.
Why?
It's big, room for almosty anything i can throw at it.
And i love the design.
Simplicity.
Now i was originally going to be doing a build log, i have some pictures but never got round to it, as you do. So i'll just give the the beast first in hand!
A quick comparison for its sheer amount of size, compared to my Antec 900 chassis.
A quick shot of all my parts Just after they got Powder coated.
Orange - Exterior (several internal bits), Matt Black - Interior.
Yes all this for £20, even including a colour swap.
I managed to get a Stanley rivet gun off 'the bay' for a couple of quid, Which made putting all this back a doddle.
Several images of me buuilding it up.
And the finished beauty.
There was a few glitches such as:
Now tell me what you think, im very pleased with how its turned out tbh.
The colour looks amazing, shinier than i thought tbh.
Future additions:
Why?
Simplicity.
- one or two of the rivets slightly push the side panels out, which im going to file down
- The removable motherboard tray didnt push in as smooth as it did. maybe the Coating build up a bit too much. Moving it in and out a lot of times, made this smoother. I'm going to be investing in a tub or grease soon for it.
- I should've used small rivets, i used 3.2x10mm throughout, as you can see too much is sticking out, which gets in the way of the fan filter. Ideally should've gone for 3.2x5mm i'd say.
Future additions:
- I forgot to mention some of the paint wasn't as good as it couldve been on the small front panel (pic inc), so i may cut a square window out of here, which would allow better intake for the fan also.
- Decals, Decals, Decals, maybe. I basically work as a Large format printer so i have all the equipment and knowledge ill need.
- Cable management. When i get all my parts back from the manufacturer.
- Extra Parts?
- hardware mods possibly, as i havnt tested it out yet with my motherboard.
- Lighting with cathodes/LED's for the front small panel to glow outwards.
- Window Mod possibly? a lot of masking tape, careful measurements and it should all look clean with abit of rubber gromet on the edges.
