Project Penguin's innards
looks fine but what case you using?>
A modified Antec 300.. assuming I actually finish it.. :rolleyes:
I would personally want a better cooler. Otherwise it's all good.
Hm, I've heard good things about the Akasa.. Any recommendations? The Titan fenrir is the main one I hear but I don't think it'd fit in the 300 without me removing the side fan.. which I don't really want to do.
I plan on going water cooled in a few months anyway.
Oh I do plan on going WC in a few months just not right now; was just looking for something cheapish that'd do me for now.. The Akasa.. tbh I know little more than it's cheapish, has 5* and is on the front page.
I do plan on fitting a side fan (that likely won't spin much tbh I just think windows look better with fans in them) so need something squat enough to fit.
heheh, I decided that I'm not going to go down the route of picking the major components just because of what colour they are... mostly.
