Intro
So - I've got plans to build an interesting ITX box. It needs to be super portable and I think even the Parvum S1 would be too big. So here's the plan:
Haswell 4670K, with ASUS ROG Impact and 7990 all watercooled with 2x240mm radiators. Power supply is an Antec HCP 850.
Colour theme - Red + White
The case is small and people have fit a lot into a Prodigy before, but usually with things like PSU extenders or shrouds for fans. I want to keep these items strictly inside the case!
Here are the challenges and plans:
This video's given me a lot of information as to how to tackle everything:
Project Updates:
1 - The case is here!
2 - The first weekend
3 - Midway
4 - So close but yet so far
**** Current Status ****
PARTS LIST
Here's the rough BOM for this. No fittings or tubing added.
In Possession Of
Purchased (In the mail or pre-ordered)
To Purchase
- Power supply is 180mm and semi-modular. Space available is only 180mm! So some modding of the Mobo/PSU tray is going to be needed. I still want to have the cables somewhat hidden, so will have some way of extending the PSU cover.
- 2x240mm Radiators won't fit as standard with 25mm fans attached. I'll have to move the top radiator more towards the back and also the front radiator down a few mm to allow clearance. The Alphacool rad is 45mm thick, so I'm just really wishing it's going to fit!! I have plans to create a custom plates out of acrylic for the top and bottom to keep this as clean as possible. Front and top will also include a mod to minimise airflow restriction.
- I want to show off the 7990 water block (when it comes in stock) and the tubing on the CPU side so will create windows on both side panels to do so.
Project Updates:
3 - Midway
PARTS LIST
YOUR BASKET
1 x Asus HD 7990 6144MB GDDR5 PCI-Express Graphics Card £499.99
1 x Asus Z87 MAXIMUS VI IMPACT Intel Z87 (Socket 1150) DDR3 ITX Motherboard £205.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £169.99
1 x Antec High Current Pro 850W Modular '80 Plus Gold' Power Supply £161.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £149.99
1 x Kingston HyperX Beast 16GB (2x8GB) PC3-17100C11 2133MHz Dual Channel Kit (KHX21C11T3K2/16X) £139.99
1 x EK Water Blocks EK-FC7990 SE - Nickel £114.95
1 x BitFenix Prodigy Mini-ITX Cube Case - Arctic White £69.95
1 x Laing 10W DDC-Pump 12V DDC-1T £54.98
1 x EK Water Blocks EK-Supremacy - Nickel £52.99
1 x EK-DDC X-RES 140 CSQ - Acetal £41.99
2 x EK CoolStream Radiator XT 240 (120.2) £38.99 (£77.98)
1 x XSPC Razor HD 7990 Backplate £24.95
2 x Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin £16.98 (£33.96)
1 x Mayhems Pastel - Red Coolant 1L £14.99
2 x BitFenix Spectre PRO 120mm red LED fan - White £11.99 (£23.98)
Total : £1,838.65 (includes shipping : FREE).
In Possession Of
- Samsung 840 EVO 250GB
- Antec HCP 850W
- Magicool 240mm Radiator
- EK Nickel Plexi Surpremacy
- 2x Scythe GTs
- Laing DDC
- Bitfenix Prodigy White
- EK Tube Res
- 45 + 90 rotaries
- Alphacool UT45 240mm
- Extenders (To go from under rad)
- ACRYLIC - Red, White, Transparant Red
- Asus Rampage Impact
- Intel 4670K
- Geil Evo Potenza White 16GB RAM
- Red coolant
- 3/8" compression fittings
- Tubing
- Braided Cables
- 2 Bitfenix Spectre Pro Red LED
- 7990 Waterblock - Nickel +Glass/Plexi
- EK PreciseMount Naked Ivy
- Liquid metal
- Asus 7990
To Purchase
- More clear tubing
- Fan shroud (why to come)
- More paint or perhaps vinyl wrap?
