Project Prodigy M Class
30 Jul 2009
Ok guys. I'm going to start my first proper watercooling project shortly and so am looking at purchasing the following:
- OcUK Tech Lab H2O Custom GTX 780 3072MB GDDR5 Watercooled Graphics Card OcUK Tech Lab H2O Custom GTX 780 3072MB GDDR5 Watercooled Graphics Card
- EK Water Blocks EK-FC Titan - Nickel Full Cover Waterblock
- Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail - Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail
- Asus Z87 MAXIMUS VI GENE Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard Asus Z87 MAXIMUS VI GENE Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard
- Patriot Venom Red 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (PV316G240C0KRD) Patriot Venom Red 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz
- BitFenix Prodigy M MATX Cube Case - Arctic White BitFenix Prodigy M MATX Cube Case - Arctic White
- EK Water Blocks EK-DCP 2.2 X-RES (incl. pump) EK Water Blocks EK-DCP 2.2 X-RES (incl. pump)
- EK Water Blocks EK-Supremacy Clean CSQ EK Water Blocks EK-Supremacy Clean CSQ
- Hardware Labs Black ICE Radiator GT Stealth 240 - XFlow Hardware Labs Black ICE Radiator GT Stealth 240 - XFlow
- Monsoon 13/10mm (ID 3/8 OD 1/2) Free Center Compression Fitting Six Pack - Red Monsoon 13/10mm (ID 3/8 OD 1/2) Free Center Compression Fitting Six Pack - Red
- Primochill Primoflex Advanced Tubing 13/10 - White Primochill Primoflex Advanced Tubing 13/10 - White
- Mayhems Ultra Pure H20 Watercooling Fluid 1L Mayhems Ultra Pure H20 Watercooling Fluid 1L
- Corsair SP120 Performance Series High Pressure - Dual Pack
Questions.
- Apart from HDD's and PSU am I missing anything?
- could someone recommend a PSU that would fit in this case and provide enough oomph to power this lot?
- Does this setup look ok? happy to take advice from seasoned builders!
You are putting a 4770k and a 780 on one 240 rad? the prodigy M looks like a crap case for watercooling. as far as im aware you can only fit one 240 and a 120 which is gonna be pushing it as far as cooling ability.
id re consider the case personally.
