So i recently re-built my pc, or shall i say, I ditched SFF and went back to "full sized pc's, albeit a case with a reduced hight.
Surprisingly, the PC is mega-loud imo, and I had thought it would be near silent, because of the components.
Current Spec:
Lian-Li V600
Corsair 520W
CPU cooler is the Nitrogon NT06 lite (passively cooled - no fan as with the "normal nt06")
Zalman cooler on my X1900XT
The case fans are what is making all the racket, and I have been reccomended 2 x Noctua NF-S12 1200RPM 120mm Silent Case Fan - 3 Pin and a fan controller.
Anyone have other ideas and reccomendation you can chuck into the mix. I never been into fans and cooling/noise levels, so think it will be a fun little project, without spending too much cash
No watercooling though, looks like too much hassle and overpriced.
thanks
Current Spec:
Lian-Li V600
Corsair 520W
thanks
